HELP PLEASE!!! F-250 starts/runsbut wont accelerate
I have a 2000 F-250 7.3 w/ 110K....This problem gradually started about 2 months ago.. if engine was cold truck would start fine, but it would not accelerate when I pressed pedal. as I throttled it, SES light would also come on. After 1-2 minutes idling, everything worked like normal and the SES light would not come on any longer...Then 5 days ago I was riding on the highway then slowed down to turn on street and the engine would not accelerate at all. When I throttled it the SES light came on ...and i cant drive truck faster than idle speed. I thought it might be the pedal assembly so I purchased one AND it still does the same thing. I have 2 codes that I retreived w/ my tuner P0603 and PFFFF. Please help!!! I dont want to have to take this baby to the dealer to get bent over...
Have you checked the Cam Positioning Sensor, what about oil level. Does it seem like it is not getting fuel. Have you checked or replace the fuel filter. Did it do this prior to the tuner being installed. Have you thought about disconnecting the tuner to see if that solves the problem. I would check the simple things before taking it to a shop and paying for something that is simple to fix. Check out the stuff I mentioned and let us know the results and we will go from there. |
I have the same problem but it only does it when I don't let it warm up long enough... Only when I start it and take off about a min. after letting it sit there. No problem at all if I let it warm up for a little bit though.... I was guessing the fuel filter but I haven't had the time to change it yet... I will have to do that soon... but my truck only has just a little over 61,000... Just wondering how often I should change it....
Hmmm....thats how mine started off...then kaput!!! It went bad. Truck seems to have fuel in it, oil level withing normal limits, CPS wasreplaced 2 years ago, when I replaced it the symptoms were similar to lack of fuel, it wouldjust turn off on me...
I have had programmer in it for 2 years w/ no problem. I went ahead a de-programmed it and didnt make a difference. I was wondering if the ICP injection control pressure, may be the fault here...Any ideas Last edited by Bronconut; 02-11-2007 at 10:19 AM. |
Is the symptom of the cps to not accelerate at all? The truck can stay on idling My past experience with cps, acts like a bad fuel filter.. Nice buck btw
Thanks for the compliment. I am wondering if your fuel pressure regulator isn't bad. But you don't have a fuel leak, usually when the fuel pressure regulator goes bad it is just the o-rings, which then cause it to leak fuel.
I don't have a code book in front of me to tell you what your codes you pulled mean I am sorry for that but I am at work and not at home. You can go to autozone or similar place and they should be able to tell you what those codes mean. Like I said before a CPS acts funny, when they go bad usually the truck will not run. But when mine went I could start it, it would idle but you get going down the road the truck would start acting up. Like I had low oil, or not getting fuel then it would just die, then you start up the truck and it would run ok. When it would start to run rough I would mash the throttle down to the floor and it would stay running but I had no throttle response at all until the engine cleared up and started running smoothly. But when my CPS went bad I could start up my truck and it would run all day idling but you try to drive it, then it would start running rough egine light would come on and eventually truck would die. Then I would put the truck in neutral and shut the key off and start it back up. Then it would run fine. I would check the cps and your OIL Level as the oil level can cause this problem too. |
Im not sure if this is the one But if it's the sensor that is in your rear end then thats it!!........Happened to me too and it's a cheap fix...Can actually do it yourself.
No the CPS is located on the front engine cover above the crank pulley at the 1 O'clock position, it has a metal tab coming off it, it is held in by a 10mm bolt, and it has a wiring harness going to it. The one on the rear end would be a speed sensor/abs sensor. |
