Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 02-18-2006, 04:03 PM
Green Horn Green Horn is offline
Question Airbag warning light stays on
Can anyone tell me where the airbag sensor is located and how much the sensor costs to replace?
Old 02-18-2006, 04:34 PM
mschn99 mschn99 is offline
does your horn work? if it doesnt, or if your cruise controll doesnt work, your clockspring under the steering wheel is bad, and that will cause all those problems. if the clockspring is good, you will need to pull the codes and see which one is there. there are quite a few things that will turn an airbag light on, also check your fuses.......Marc
Old 02-18-2006, 04:41 PM
My horn and cruise control seem to work alright, right now I don;t have any way to pull the codes. Thanks
