Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 07-01-2009, 06:32 PM
korg70kbc korg70kbc is offline
Exclamation codes
Hi,
I need help with codes. I have had tons of problems w/this truck's electrical. I have a new fuse/GEM panel, its just not installed yet.
All (most) of the codes below were caught by doing the "test on board systems"
I have no MIL/SES light, which leads me to believe something more is going on with the fuse panel then just my one touch relay having no power to it.
I'm having issues with the truck acting like it's starving for fuel, ESPECIALLY under load. I haven't done a fuel pressure test yet.
The truck has 182k on it, & 2 weeks ago, it was running perfect. Di a oil change about 1000 miles ago, tranny was serviced 2 weeks ago, I originally thought it was a suspension/tranny problem, I had my rotors turned, & things somewhat improved, but now, I think theres a whole lot more going on. It almost seemed like I could feel a vibration under my feet, but no one in the vehicle could feel it. Then as the problem got worse, others could feel it, barely, at least until it got bad, then I wasn't so "crazy".
I have also felt like it was a throttle problem, as it is slow to respond.
I did KOEO, KOER, Cylinder contribution test, & injector buzz test
P0476 Exhaust Pressure Control Valve Range/Performance
P0565 Cruise Control ON Signal Error
P0566 Cruise Control RESUME Signal Error
P0567 Cruise Control RESUME Signal Error
P0568 Cruise Control SET Signal Error
P0569 Cruise Control COAST Signal Error
P0284 Cylinder 8 Contribution/Balance Fault
P0220 Throttle Position Sensor/Switch B Circuit Error
P0571 Cruise Control/Brake Switch A Circuit Fail
P0703 Brake Switch B Circuit Error
P1536 Parking Brake Applied Failure
P1780 TCS Circuit Out of self Test Range[/b]
these are codes that come up every time I search for DTC's
B1203 Fuel Sender Circuit Short to Battery-Msg Ctr
B1352 Ignition Key-in Circuit Failure - Instr Clstr
B1871 Pass Air Bag Deactivate Fault - RCM--(per AE) disable module fault I think I turned it off
B1884 PAD Warning Lamp Inoperative---or AE: " " circuit failure
P0500 Vehicle Speed Sensor (VSS) Error -- per AE (sensor A)
previous codes,
__________________________________________________ _
C1200 ABS inlet valve coil LF circuit short to battery
C1223 lamp brake warning output circuit failure (I 'thought' it was cargo bulb)
B1450 Wiper Wash/delay switch circuit failure
B1428 Lamp seat belt circuit failure
__________________________________________________ ____
manifold absolute pressure 12.7 PSI
injector control pressure Volts .19
exhaust back pressure-volts .73 V
Vehicle power voltage 12.3 V
desired engine RPM--0.00
fuel pulse width #1---0.00
fuel injector pulse width---0.00 ms
volume fuel desired 9.7mm3 at idle
after clearing codes the continuous codes are:
GEM/Central timer--- , B1352
Airbag---B1871, B1884
Overhead trip computer----P0500
AND with KOER---P0476
I have no vehicle, as I will not drive it like this.
ANY CLUES????
thanks,
Laurie
could the wastegate, (that has been sticking off & on) be the cause of this??????
