Engine Position System Performance bank1
p0008
Engine Position System Performance bank 1 does any one no anything bout this or how i fix it or a link or something |
Maybe your bank one injector is going bad. Not sure tho. Whats it doing?
not doin anything bad ..... knock on wood..... but i get ses light for bout 2 minutes when i get on it in 100 horse setting and i pulled some codes and im just trying to get some explanations
Do you have a map fooler on it, if not, you are probably getting an over boost from the MAP sensor. Do you have guages too, if you are boosting over 24psi, that more than likely what that is.
naw my peak bost is right around 20psi my compressor wheel is chewed up from the dunes im in the process of ordering a ww
Oh, there is something else that can cause that, but I dont remember what it is right off hand.
well if you come up with anything let me no
Maybe one of the boots on one of the pipes that go to the turbo, heck...I dont remember. Maybe someone else will chime in here before too long.
I wonder if that is a code being thrown by the Bully Dog under hard accel. And you should still get a higher boost psi with the bully, than that I'm thinking, are you sure your getting an accurate reading on the boost? With my DP I'm hitting 30 uphill.
Gord. |
ya i am the reason my boost is lower is because my compressor wheel is chewed up..... i am getting ready to oder ww...... to install that would i have to take the turbo off or what
