A/C Relay Location on 99' F350 PSD
My A/C has a good charge but turns off after running for 20 minutes, then comes back on in 10 minutes and just does this as long as it is on, I assume the relay is bad but I can not find the A/C relay.
Can someone tell me where the relay is? Has anyone ever had this problem before? |
Anyone recommend a manuel to find the relay location?
Anyone have any ideas on the relay location?
there is no relay. what you want to check when ac quits working you want to see what your pressures are reading. you could be dealing with just a bad connection or you could be dealing with you orfice tube be plugged causeing high pressure.
Thanks for responding. I will check my pressure and pressure sensors etc.
just a thought
my a/c pressure sensor on the compressor was bad,so i replaced that, but the connector seems to be somewhat loose so my compressor clutch won't kick on and blow cold air unless i jiggle the wire or zip tie it just right. other than that, it's some dang cold air. so i know the charge is good.
it could also be excessive compressor clutch gap... should be about .20 or so i believe.. like the thickness of two business cards... next time the a/c isn't running tap on the clutch quickly witht the engine running and see it it engages..also if that does work give the pressure switch, on the accumulator a lil love tap...
