2005/2006 sunroof fit in a 2002 psd???
I have a 2002 psd no sunroof. I want to put one in it. I am planning on using one from a 05 06 King Ranch or Lairat. Just wondering if anyone has done this?
Are you talking just a regular sunroof. Or the power moonroof unit?
If you are talking the power unit. The wiring wont be there but it should fit |
The whole set up..I am not worried about the wiring just wanted to see if anyone came across any probs if they did do this
Not to jump in or anything, but I am also wondering if anyone has done this, cause I would like to put one in my EX.
Same here don't know of any problems you would run into, but I would like to see a write up on this so I could do the same. Good Luck.
The only problem that i have heard of anyone having with it is leaks caused from the cuts that are made. Plus when you make an aftermarket seal with silicone it will never be as strong as the factory ones due to them being able to heat it up so high. But if you have the knowledge and patience. It would be a great mod. I love mine. Good Luck
subscribed
I don't see why there would be any problems if its done correctly You can have a dealer install the factory sunroof, so there shouldn't be much of a difference from what i can tell. Unless they use different parts or some kind of kit. Id call a dealer to see if it can be done and maybe how they do it.
The ribs on the roof of a truck with a moonroof are different from a truck without. You would have to do alot of body work to make a factory moonroof work. I've checked LOL.
A place around here does sunroofs, and they cant do it on my 2000 Crew cab, because of the ribs on the roof.?
