01 ext cab subs? - Ford Powerstroke Diesel Forum
Old 03-25-2009, 11:35 AM
01 ext cab subs?
Can you lift the rear seat in order to fit subs under the seat? whenever someone sits in teh back it keeps cutting my subs
also are these any good?
2 10" kicker cvrs also they are the 4 ohm dual voice coil model.
Old 03-27-2009, 07:17 PM
dont know about the subs but yeah you can lift the rear seat and make a box. i posted pics in the other thread. also if you want PM me if you want more pics. It looks like it came that waya from the factory
Old 03-27-2009, 07:38 PM
I have Kicker Comp 10's. They are really nice. CVR's are a step up. 2 of those will fill the cab with bass very nicely
Old 03-31-2009, 10:00 AM
I installed one Kicker Solar Baric L7 12in in the front center console/seat and kept all the usability of thee seat and center console.
Old 03-31-2009, 07:11 PM
Had the same problem in my '02. I pulled the seat, drilled 4 new holes and move the seat about 1" forward. Problem solved You lose a little leg room in the back seat, but was not an issue to me. Not sure if you can do it in the ext. cab, mine was a CC.
Old 04-01-2009, 05:11 PM
There is a website where you can buy a box that fits nicely under the extended cab seats.
Subwoofer Enclosures|Subwoofer Boxes|Custom|Vehicle Specific - Ford F-250/F-350 Extended Cab 01-08 Dual Subwoofer boxes
Old 04-01-2009, 06:02 PM
here is the drawings i did for my box. this is holding a 10" alpine sub, and sits underneath the seat with the 2x2 lift. I built it out of 3/4" plywood and I made it so i didnt have to move the jack. If you would like more PM me and i can do my best to get more dimensions etc. you dont see the dimensions on the back because i have mine different then other people could want/have. the hole in the back of the box is obviously were the seat touches the groud for support and i made it so it fits tightly around it.
Old 04-01-2009, 11:51 PM
Wow thanks for the dimensions... I need to build one w/ those drqawings I could just drill another hole an run 2 also right? I'll need to do this soon as it gets warm out! thanks I really appreciate it
Old 04-02-2009, 06:20 AM
yeah you could. but if you have seen pictures of mine i have a little storage comparment for my towing straps where the little seat is. I think if you ran 2 subs you would have to not do the storage comparment because of the airspace need to max output/performance of the sub.
