GUAGE HELP - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-07-2009, 04:43 PM Thread Starter
GUAGE HELP/DASH MOD
just installed the f650 dash mod. my in/out temp. guage has two wire for the dimmer control, and i dont know which wires to tap into. instructions say:
orange 12v ignition switched feed for hi backlight
blue 12v instrument panel lamp circuit feed for low backlight
anybody know where to hook these up at, and yes this is worthless without pics, but i've worked on it for about 5 hrs, after work, im tired and hungry. i will post pics tomm. when its daylight, thanks
19558077 is offline
post #2 of 20 Old 03-08-2009, 05:02 PM Thread Starter
got some pics today. cut three bottom gauge holes for when i can afford them, which looks like not anytime soon. i have to get one more plug and paint it, there was only two plugs in town i could find. the switches are just a tad crooked, i didnt have anyone to hold the switch cutter.the strobe switch operates my hideaway's on low, and the hideaways, and dash light on high. the work light switch will operate an auxilary back up light, and i put a spare switch for later on.
19558077 is offline
post #3 of 20 Old 03-08-2009, 08:49 PM Thread Starter
seriously nobody!!!!!!!!
19558077 is offline
post #4 of 20 Old 03-08-2009, 09:32 PM
ford_trck's Avatar
Send a message via AIM to ford_trck
I have no idea but here is a bump for ya
Early 99 F-350 CC LB 6-speed
Stock with mods
Originally Posted by CloverLeafFarm View Post
Hey Ross, after talking with you i did some research and seems like you chose the right path to go, i knew you were a super genius!
Ross
ford_trck is offline
post #5 of 20 Old 03-09-2009, 01:20 PM Thread Starter
19558077 is offline
post #6 of 20 Old 03-09-2009, 05:42 PM
Once you go black......
CanadianDiesel's Avatar
Send a message via MSN to CanadianDiesel
Free bump. So you need the gauge backlight wire to tap into a wire for the instrument cluster? like when you turn the lights on? And then what do you need for the backups?
Then & Now
Matt
'99 F-350 4x4 7.3L
6637, 4", chip; far too many upgrades to list.
Coming soon: Rigid Industries Lighting, Nav, On-Board Air.
Latest mods: Line-X, '08 Black Leather Captain Seats (Lariat), Trans, EGT and Turbo Gauges; TS chip, Chrome Delete.
02 VW Jetta TDI - 40mpg
CanadianDiesel is offline
post #7 of 20 Old 03-09-2009, 05:45 PM Thread Starter
i just need to rewire the backups, to do away with the relay i screwed up somehow. yes, i do need the dimmer/backlight for the temp gauge. it comes on at startup but then goes off. i dont know where to tap into
19558077 is offline
post #8 of 20 Old 03-09-2009, 05:48 PM
Hmm...sorta stumped for that one...but all the guys with gauges on here should know that one
I'll have to do this when I get my gauges so hopefully someone comes along.
But wiring the backups should be fine right
post #9 of 20 Old 03-09-2009, 05:57 PM Thread Starter
yeah, for some reason im not getting 12v out to the light, so im gonna do away with the relay since its only one 55watt light.
19558077 is offline
post #10 of 20 Old 03-09-2009, 06:27 PM Thread Starter
sorry to take so long to respond, im trying to do some insurance claims. if i find something out i will let you know. i like my strobe switch with hi and low. on low i just have the hideaway's on. and on hi i have the hideaways, and the strobe dash light. good luck
19558077 is offline
