CB Antenna Wire Instalation - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-06-2009, 03:18 PM Thread Starter
Hi all,
I could use some help installing my CB antenna coax. I am new to my 2001 F-250 Super Duty, Crew Cab.
I know there's a grommet or 'hole' behind the back seat. Is it easiest to run the antenna wire under the carpet on the 'hump', or around the side by the door jams, or through the fire wall and then under the truck along the frame?
How do I access the 'hole', does the back panel just pull off or are there hidden screws?
Binkowski is offline
post #2 of 2 Old 03-06-2009, 03:21 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I ran mine alnog the frame and through the hole under the gas pedel!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
