Power Inverter
Hi all,
So, I am new to my truck and Ford's. I love my crew cab, but was wondering if anybody has 'hard wired' a power invertor in to the dash? I did a search and didn't find anything. But I can't help but wonder why Ford, (or any of the maufacturers), don't just install an OEM power invertor? I think the newer 2008/2009 do. I was replacing burnt out dash lights and there looks to be plenty of room back there to install a power invertor. I know these things do produce a lot of heat, so is that the main issue? Gotta figure out how to put a signature on here... 2001 F-250 Super Duty 4x4 CC SB completely stock...until I learn more about Fords |
I was thinking the same thing the other day. I would love to have a built in Power Invertor in my 04
I dont know about the inverter but for your signature, go to User PC and then on the left click on edit signature
You can certainly install an inverter. I have a xantrex 1750 mounted in my 2000 PSD. It is up under the dash. I was orginally planning on even routing a spot to install outlets, but have found that it is easy enough to reach the outlets on the inverter. When you install you will need to add a fuse between the inverter and the battery. All in all, the hardest part of the job is figuring out how to mount the inverter. Good Luck
I plan on doing this to mine soon. Where under you dash did you mount your inverter at sharphedin?
That looks like a good setup. How big is the inverter?
The Inverter that I "WILL BE" installing is a 2000watt cont/4500watt surge
In the picture, that is my subwoofer amp, the inverter will be going on the passenger side of it. The PlayStation 2 will be going on the Driver side. |
Thought that something didnt look right!
i put a little one in the glove box... i can run pretty much anything off of it.
