Cruise Cont. and Horn Dont Work
About a week ago I was on my way to work and pulled out onto the highway, got it up to 70, and tried to set the cruise. Nothing happpend, I also tried the horn and it doesnt work either, and my air bag light is on on my dash?
anybody know what the prob. is???????
Check the horn fuse, my cruise went out and it was because that fuse popped.
Checked the fuse, its solid...........
Does your lights in the steering wheel still work? If not, the ribbon wiring inside the column broke. It is easy to replace.
probly the clock spring in the steering column if nothing on the wheel is working
Ok, that's making sence now that all the lights on my cruise controls are out, and horn, and cruise isn't working. Any body know how to fix that, and how much the "Clock Spring" is?
I've only done a few of them and never on a super duty, but if u unbolt the air bag from the back of the wheel (un hook Both batterys and wait 10 mins)
and unplug airbag. behind that ther will be a large nut undo that take the wheel off, probly gonna have too pull real hard to get the wheel off and theres the clock spring. make sure u make a mark on the wheel and steering shaft so the wheel goes back on straight. the clock spring will probly be $50-$75 |
Ok, thanks guys I appreciate it, it's been killing me not to have cruise on long trips
I just had to replace my ribbon wire or w/e its called it was like $120 or so... now everything works fine.
