Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 01-19-2006, 12:39 PM
mgwerks mgwerks is offline
Overhead Console woes.
I have a 2000 350 CC Lariat, and the overhead console doesn't work - kinda. At night, with the lights on, both of the buttons are illuminated, but the display is not. If you press on the mode button hard for 10 or 15 seconds, the display barely lights enough to make out the numerals in the dark. It appears from cycling through the functions that they all work, it just isn't lit up like it should be. Any ideas?
Mark
Old 01-19-2006, 09:15 PM
lilredpowerstroke lilredpowerstroke is offline
Have you tried the dimmer switch by the headlight switch????
Old 01-20-2006, 07:20 AM
Um, yeah, the dimmer works normally, but thanks. On another site I found references to problems with resistors soldered to the electronics in the console, and that resoldering them usually corrects this.
Old 01-23-2006, 07:34 AM
Well, I resoldered the resistors (replacing one), and the displayu came back to life! There is one odd thing, though, and that is that the MPG AVG display reads 14.1 all the time, no matter what you are doing or for how long. Paper computation shows actual mileage adn it is never that low. Hmm...
Mark
Old 01-23-2006, 09:58 AM
The overhead console is not very accurate. I would always do my own calculations.
Old 01-30-2006, 03:34 PM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
Have you tried reseting your MPG, you hold both buttons in for so long and it will reset to zero, 14.1 might be the all time average if it has never reset...
Everything works on mine except the temperature.. I took it apart to clean up there and I noticed that the left side, one of the terminals as you are looking at the screen looks burnt out... assuming this is the temp, is there a way to fix it, how much does it cost to replace just the screen??
Old 02-17-2006, 02:55 PM
BSMILEY BSMILEY is offline
Send a message via MSN to BSMILEY
My digital temp. guage in the overhead console does not work, it stays on -40
all the time, I talked to a ford mechanic, he pointed out the outdoor sensor on the drivers side, just behind the grill, could this be the problem, any suggestions would be much appreciated. I have a 2002 lariat 7.3,4x4, crew, one ton dually, auto.
Thanx
Old 02-17-2006, 08:14 PM
00powerstrokin 00powerstrokin is offline
Moderator
Send a message via Yahoo to 00powerstrokin
my half ton was doing that. i replaced the sensor behind the grill and it was fine. 16$
Old 10-25-2009, 09:59 AM
Ak powerstrokes Ak powerstrokes is offline
I just bought a new circuit board, from an online company, it works great but my temperature also says -40 F and C also my mpg is way off. They also will give a core for your old circuit board. The cost was $180 approximately
Old 10-25-2009, 04:06 PM
blandproud blandproud is offline
what resistors can you use and where did you guys get them?
