Odd Power Window Issue... Completely Stumped! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-15-2014, 12:11 PM Thread Starter
Hey guys,
I'm having an issue with my passenger side power window not rolling down. I figured the motor was shot, so i bought one and upon pulling the old motor, i found it to roll up fine but it won't roll down. I plugged the new motor in and found the exact same issue. Will spin in the roll up direction but not in the roll down direction. Here is where things get weird...
I tested the leads to the motor. There are 2 wires one sends a signal to roll down and the other sends a signal to roll up. I tested the wires and both are getting 11.9 volts when either button is pressed. If the roll down button wire is getting power how the hell does the motor not activate. Again both motors are showing this symptom.
Additionally, if you hit the driver side switch I don't get anything. Could a bad driver side switch cause the passenger side to malfunction? Its driving me totally insane. Any help would be great!
Has anyone ever experienced this?
Edit: Just jumped 12V to the motor and got it to spin in both directions. The Motor is clear. It appears that I'm getting a complete circuit in the up but not in the down. Im guessing the switch is bad...
Ty_Deschaine is offline
post #2 of 4 Old 06-15-2014, 03:59 PM
Quoted: 13 Post(s)
I think you are correct. I assume the window switches are wired similar to door lock switches. Where, if one is unplugged, or bad, the other won't work properly. Switches are fairly cheap so I would get a replacement and I will bet it solves your issue.
Will335i is offline
post #3 of 4 Old 06-15-2014, 04:23 PM Thread Starter
So I checked continuity between all wires on both sides and found a break in the Salmon/Blue wire. So I checked the wire at the door jam... and..
Walah! The culprit. Reconnected it and its all good to go. Window is fully functional via both switches.
post #4 of 4 Old 06-15-2014, 08:01 PM
StrokinAlaska's Avatar
Dodges are notorious for cut wires in the boots. Good to see someone found an issue we may all encounter soon!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
