Sound Insulation.. What is everyone using and how much? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-06-2014, 05:12 PM Thread Starter
the1laf's Avatar
My truck has been missing most of the insulation on the engine side of the firewall, as a result I can barely carry a conversation with a passenger, have my music near max to enjoy it and can barely use my phone on the road.
I'm thinking about a new head unit, speakers, and throwing some insulation in the front doors and behind the dash as a starter.
What insulation have you guys found to work best and what should I stay away from?
How much is everyone using?
Thanks,
Will
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #2 of 15 Old 06-06-2014, 05:33 PM
Quoted: 21 Post(s)
Thanks,
Will
Look into mlv. If I remember its multi layer vinyl. Great write up on powerstroke army forum
The Next Level is offline
post #3 of 15 Old 06-06-2014, 09:33 PM
StrokinAlaska's Avatar
We use Dynomat, Ballistic,and Hushmat at my shop, all the same stuff different names. I did 3 bulk packs on my truck (4 door crew cab 7.3). I did the inner door panel and the outer on all 4 doors, the back wall, the pillars and the headliner. Indoors weigh a good 65 pounds now and sound like knocking on steel. I have dual 8inch stacks and it helps a lot with silencing it all on the road. You can buy other stuff at hardware stores like home depot and Lowes. There's a lot of stuff out there. Doing your doors and floor will help a bunch!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
The Following User Says Thank You to StrokinAlaska For This Useful Post:
the1laf (06-07-2014)
post #4 of 15 Old 06-06-2014, 10:58 PM
Quoted: 8 Post(s)
I used the rolls of HVAC wrap that you can get from lowes/home depot. Probably not as good as dynomat or the like but definitely made a difference and a fraction of the cost. It is a thick foil with foam self adhesive backing. Pretty simple to install, just clean the surface you are putting it on and use a roller to apply it.
Will335i is offline
post #5 of 15 Old 06-06-2014, 11:56 PM
Rodslinger's B1TCH
this all seems awesome to me
steve604 is offline
post #6 of 15 Old 06-07-2014, 06:52 AM
Joel's Avatar
Quoted: 10 Post(s)
If you don't like it now, never get single shot injectors.
I used laminate flooring foam underlay in my doors. It made a noticeable difference, but the truck is still too loud to have a conversation.
I ended up getting new door speakers and a sub. That was a better solution
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 15 Old 06-07-2014, 08:25 AM Thread Starter
the1laf's Avatar
Thanks for the info, I was thinking along the lines of dynomat but I didn't know how much I should buy.. Crew Cab's are a little bit bigger than a "standard" vehicle lol
Trust me I'm redneck, I've been rolling with it for the past 5 years, but a couple weeks ago I had the music cranked (just to distinguish it from the motor) and i didn't hear my radar detector going full ramp.. Yea.. That was one of the few nice cops I've met but I don't need to do that again.
That's another reason I want to do this, I'm so restricted in the power department with stock split shots, and singles are louder..
My goal is to get my truck into around the same range as the other 4 7.3's we own, maybe just a touch lower, the stereo can take it from there.
the1laf is offline
post #8 of 15 Old 06-07-2014, 10:32 AM
Buy a 4 channel amp and get some actual power to your speakers, factory or not they will be night and day difference with an amp. I do about 70mph with all my windows down, if I turn up my stereo you wouldn't know the windows where down besides the breeze cuz you only hear the system . its great
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #9 of 15 Old 06-07-2014, 10:34 AM
Then if I roll my windows up you'd never know I had a strereo at all with how much sound dampening is in there. When you do decide on what material and brand your doing don't skimp it or you'll just want to redo it, be generous with the amount used!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #10 of 15 Old 06-09-2014, 10:05 AM
heykw's Avatar
I'm thinking about doing the same thing with an excursion, I just have no clew what to use or how much I will need. It sounds like its a worth while upgrade for sure I have single shots and a 38r.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
