center shifter in my 99 - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-07-2014, 11:31 PM Thread Starter
StrokinAlaska's Avatar
So after searching around and seeing the fellow powerstrokers OBS install, I decided to try it as well.
Bought my center shifter from a junkyard here in Anchorage for 80$ . took the console , shifter cable,and all wiring plugs with 10" of wire on it to have some play room (not important to me as I do wiring,but important if you don't have access to wiring!).
Started off by cleaning the console as our trucks at junkyard sit in the elements. Cleaned up nice and got it all pulled apart to clean any deep burried dirt.
Next I pulled my center seat out , its a 40/20/40 split or jump seat whichever y'all call it. It takes a T55 torx to pull the seats, and a 16 or 17 deep socket to pull the other seat bolts. A 10mm ratcheting wrench or short socket to pull the jump seat itself.
Easy simple fast removal, straight toward.
I will post pics as I continue ! Hang in there
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #2 of 15 Old 05-08-2014, 11:57 PM Thread Starter
I need help on seats, as my seats aren't wide enough with this new center shifter console, I know the 04-08 f150s are wider and the 08up super duty's are as well. Will f150s fit or do I need to do super duty's
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #3 of 15 Old 05-09-2014, 01:42 AM
alaskan155's Avatar
Quoted: 60 Post(s)
F150s are narrower than the superdutys
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 15 Old 05-09-2014, 07:36 AM Thread Starter
OK well that solves that issue. I'm thinking of dropping 08+ black leather seats in .
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #5 of 15 Old 05-09-2014, 10:43 PM
Do you have leather seats currently? If they are grey colored, Id drive up from Soldotna and buy them if you change seats.
Oh, BTW: Nice project. Look forward to pics
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #6 of 15 Old 05-10-2014, 12:05 PM Thread Starter
No I have the tan. What seats you got? And thank you, iI'll eventually get further then pulling the jump seat and just have g the shifter in there for feel haha.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #7 of 15 Old 05-10-2014, 02:40 PM
Quoted: 8 Post(s)
I am interested to see how it looks when you are done.
Will335i is offline
post #8 of 15 Old 05-10-2014, 03:41 PM Thread Starter
I've been taking pics, but haven't gotten far, when its all done I'll load them up for y'all don't worry!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #9 of 15 Old 05-19-2014, 07:41 PM Thread Starter
Finished with the wiring, od light and shifter cable. Drives and functions just need to securely mount itg. Gonna raise it since I don't like how low she sits, go up about 1.75 to 2 inches. Its amazing having a center shifter. As for the hole in my shroud, I'm ordering the shroud from a Manual trans truck as it only has a slot opening for the key release. Then fab a Abs insert and paint it to match.
Install is easy! Wiring is slam dunk, for me agt least and don't worry I wrote down the wires and all that. Cable relocation was OK, u have to mock up the cable lock since the superdutys is a little longer. I used abs and some screws and a dremel to replicate the same lock in but obvioulsy 1.5inches longer to compensate for the difference.
For the od light I flush mounted a 3mm led light in the console and wired her up. Can't see it until its on, perfect!
I'll post pics but the forum doesn't like my tablet much so its kinda a pain.
I got my console for 80 bucks at the junkyard. Materials to install free, since I work in a shop.took me 3 hrs to do after I stopped surfing Google and the F150 Forums where I found my wiring guides.
To all who may want o do it. If you can get that console for a decent price, go for it!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #10 of 15 Old 05-23-2014, 11:46 PM Thread Starter
Sitting n place
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
