Key Remote Reprogram - Ford Powerstroke Diesel Forum
Old 12-18-2008, 09:34 AM
my key remote wont work and i forgot how to reprogram it its somthing like turn the ignition on and of a certain amount of times and than press the lock button on the key fob
does anyone here know how too?
Old 12-18-2008, 09:35 AM
<-Day Of Fail now SOLD
Read your owners manual. Somewhere in there is tells you how.
Old 12-19-2008, 05:55 PM
Electrical Ogre
Um...here's the procedure from the owner's manual (in case you don't have one)
Programming remote transmitters
It is necessary to have all (maximum of four — original and/or new) of
your remote transmitters available prior to beginning this procedure.
To program the transmitters yourself:
• Place the key in the ignition and
turn from 2 (LOCK) to 3 (OFF)
and cycle between 3 (OFF) and
4(ON) eight times in rapid
succession (within 10 seconds)
with the eighth turn ending in the
4 (ON) position. The doors will
lock/unlock to confirm that
programming mode has been
entered.
• Within 20 seconds, program a remote transmitter by pressing any
button on a transmitter. The doors will lock/unlock to confirm that the
remote transmitter has been programmed. (If more than 20 seconds
pass before pressing a remote transmitter button, the programming
mode will exit and the procedure will have to be repeated.)
• Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has
been programmed.
• When you have completed programming the remote transmitters, turn
the ignition to 3 (OFF) or wait 20 seconds. Again the doors will
lock/unlock to confirm programming has been completed.
