stock stereo won't come out... am i missing something? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-28-2014, 09:23 AM Thread Starter
skkele's Avatar
2002 f350 stock 6 CD in-dash changer.
I've got the removal tools (u-shaped things). push them in the requisite amount and can feel them engage... but the darned stereo just won't pull out!
thanks!
2002 F350 CC LB 4x4 Lariat
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #2 of 4 Old 04-28-2014, 09:30 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Its pretty tricky. Make sure they are pushed in ALL the way. IIRC(was several years ago) it seemed to "bottom out" and still wouldnt come out and i had to push a bit harder while finagling it in and it eventually goes down one more "notch" and then it comes out.
Make sure you try pushing the pins away from the radio as well as in towards, IIRC as well it was counter intuitive of which way you would think it would come out
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 4 Old 05-19-2014, 06:32 PM
StrokinAlaska's Avatar
Got to push the pins in to the radio or out to the doors, don't remember. Don't be afraid to man handle her a bit, it won't break on you. You'll fill it get loose
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #4 of 4 Old 05-19-2014, 06:45 PM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
I used 4 nails and pushed them all the way in. I believe you push them towards the center of the deck and then pull out. You can also pull the whole dash bezel with radio installed and then you can pull it while looking at the back.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
