Gem module beeping inconsistently - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-27-2014, 01:40 PM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
Gem module right below headlight switch keeps beeping in consistently. When it beeps it's 3 sequences of 5 beeps. Took it to ford dealer dad works at & there is several codes. Nothing definitive though. Door ajar light won't come on ( replaced bulb) door ajar switches both work as they should. Air bag chime code. I'm stumped on this. May have to go back to dealer for more diag. Any ideas?
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 3 Old 04-29-2014, 08:26 PM
Eco Taxi's Avatar
Ugh I feel your pain. I have the same series of 5 beeps and haven't figured it out either. I've posted several threads on several forums about this without an answer outside that it relates to a airbag chime code. I haven't really had time to tear into it either.
If you take it into the dealer for further diag. Share the results
Good luck
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 3 Old 04-30-2014, 07:28 PM
Eco Taxi's Avatar
https://www.motorcraftservice.com/re...e=EN&viewer=IE
Look here for info
Click air bag module on the left side
Kyle
Eco Taxi is offline
