Pulled dash apaert and now Air Bag Light - Ford Powerstroke Diesel Forum
Old 12-15-2008, 04:43 PM
Pulled the dash piece off and when I hooked it all up, my air bag light wont go off and my pass air bag off switch doesn't work, we check it 4 time to make sure it was hooked up and still nothing
Any thoughts?
Old 12-19-2008, 08:26 AM
ARMY MOM!!!!
Send a message via Yahoo to korg70kbc
Any thoughts?
MINE 2!!! Same thing, I thought it was something else, like NO air bag
Hopefully someone will answer u
Old 12-19-2008, 08:32 AM
What dash piece are you talking about??? The part where the key cylinder is??
Just FYI. Anytime you do anything even close to the air bags your supposed to disconnect the bats. You don't want the air bag deploying while you have a screw driver in your hand.
You may have to reset it but I have never had a problem connecting and disconnecting air bag plugs but the bats were always disconnected.
Old 12-19-2008, 08:51 AM
ARMY MOM!!!!
I COMPLETELY took my batts out while I worked on my dash, I was totally paranoid those things would go off! But my key cylinder doesn't work either
Old 12-19-2008, 06:58 PM
Well ...... I didn't disconect the batts. Had too much beer to care about an airbag deploying. So whats the fix?
Old 12-19-2008, 09:14 PM
ARMY MOM!!!!
ummm, I'm waiting to find out from ur thread.....my light still comes on, I wish someone would answer u!!!!!
Old 12-20-2008, 05:19 AM
If ya'll are sure you didn't leave anything unplugged then I think your only option is to pull codes on it and go from there. Im pretty sure those generic scanners won't do it. If you don't have auto enginuity or another good scanner then you'll have to take it to a shop that can pull codes on the air bag system. The ones at autozone only do emissions as far as I know.
Old 12-20-2008, 05:23 AM
Raging Lunatic
I didn't take the batts out well.....................
Old 12-20-2008, 06:11 AM
the air bag light will flash the code turn key on .a tone will sound then light will flash the code then use the power of the computer to fid code number there is a place to reset the light on most cars and truck most of the time next to the air bag moduel
Old 12-20-2008, 06:33 AM
Already tried pullin codes with my superchips, and nothin. I'ts not a huge concern of mine and I am willing to waite till I get AE.
So your sayin when I turn the key on and the airbag light flashes, its giving me the number of the code like the OBD 1 systems? Where can I get the definition of the codes?
