Data Cluster on roof - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By StrokinAlaska
post #1 of 4 Old 04-16-2014, 09:06 AM Thread Starter
My data cluster is giving me fits. First it didn't work at all. I took it off and found that the thing had a loose plug. Now it works, but it is so dim that I can't see it. Any suggestions as to what I should do?
goodoldboycraig is offline
post #2 of 4 Old 04-16-2014, 10:02 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
So is there any light at all? Do your tail lights work? Mine had no back lighting but all dummy lights worked. I blew a fuse. It's in the engine compartment fuse box. I don't remember which one it is tho. Sorry.
EDIT: that was my gauge cluster. I just realized you where talking about a different one sorry. I have no clue.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 4 Old 04-18-2014, 09:47 PM
StrokinAlaska's Avatar
Pull it and resolder the resistor. Easy to do, or send it I. There's a guy who fixing them. Can't remember who it is but if u look around you'll find it. Yourself is a 20 minute job, just pull her down, and I believe its torx to remove the board from the plastic overhead.
skkele likes this.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #4 of 4 Old 04-22-2014, 04:51 AM
MyAirbags: $49 Module Reset and Replacement, $65 Seat Belt Repair : ABS Repair: Climate Control, Car Clock, Overhead Console : Cluster, Dashboard and Instrument Cluster Repair : Myairbags.com or call them at 678-778-8890 in Duluth GA.
I had 3 resistors that were loose, I soldered them but that didn't work, so I had to sent it to them. They had it fixed and back to me in a week, cost $30 plus shipping.
bertieb is offline
