AIR BAG WARNING ON DASH - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-11-2014, 04:26 PM Thread Starter
AIR BAG WARNING LIGHT ON DASH
Just recently the air bag warning light stays on or goes off and on at different times. I have Isso Pro gauges and upgraded the DP tuner to and F6. Somewhere I read that you don't want to connect the gauges to a certain wire under the dash. Might cause the air bag to go off. The air bag light goes off and on any time. Can drive down ruff dirt roads and the light will be off. Turning the steering wheel has no effect on it. Also using the tilt wheel has no effect. I did notice on a couple of occasions when first starting the truck the air bag warning light would stay on till the symbol for the oil pressure light went off. Then the air bag symbol would go off. That air bag warning light goes off and on at random.
The pickup is an E99 F350 CCLB w/a 6 spd. Any help would be great.
Thanks
COP-OUT is offline
post #2 of 4 Old 04-18-2014, 09:05 PM
StrokinAlaska's Avatar
What wire you tag for your Ignition and 12V constant for your gauges?
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #3 of 4 Old 05-01-2014, 04:18 PM Thread Starter
wiring.
I'll have to check. Been out of town and pickup is in body shop.
Thanks
COP-OUT is offline
post #4 of 4 Old 05-19-2014, 06:56 PM
For 12v constant you want Light Green/ Purple, or Yellow.
For Ignition you want Red/ Black, there will be 2, use the Bigger one.
Fuse them both, 10amps should be good.
The wires will be heavy gauge under there, bout 12-14 gauge
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
