Little Sound System Help Please - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-31-2014, 01:49 PM Thread Starter
bieryjake's Avatar
I'm a bit new to the whole subwoofer thing and had a few questions. I came across a good deal on 2 alpine swr-1222d subs and I am a bit lost on how to wire them. I think I need a mono channel amp with about 1000 at 4 ohms but after that I a little lost on how to wire the amp to the subs so it works right. I understand the wires to the sub from the battery and the radio...thats simple but the rest is a little eh. So any help would be wonderful.
19 years old and currently going to UNOH for Auto/Diesel Associates Degree
2000 F250 ECLB Lariet
Terminator T500
Farm Boys Diesel 5" Turbo Back Exhaust
bieryjake is offline
post #2 of 7 Old 03-31-2014, 02:13 PM
ZMANN's Avatar
Quoted: 1651 Post(s)
12volt.com has what you want
We Miss you Ronnie
ZMANN is online now
post #3 of 7 Old 03-31-2014, 06:57 PM
TPlatt's Avatar
Quoted: 3 Post(s)
Wire your radio to your amp. This will be remote wire and plugs(similar to a/v cables just without video). Wire your speakers to the amp. Ground the amp and run a power wire to battery and please use a fuse about 6-8" off the battery terminal.
2002 F-250 XLT. TS 6 Pos. Chip, AFE Magnum Force Stage II Cold Air Intake, 5" Exhaust from turbo back. Halo-projection led headlights, Custom Raptor Style Grille, 66004b road armor bumper, smittybilt x-20 10k winch, 2012 Tailgate, Ranchhand Rear Bumper, 6" lift, 08 Dash Swap, 08 mirrors, 4x Infinity Kappas, JBL GT5-2402BR, And a lot more.
TPlatt is offline
post #4 of 7 Old 03-31-2014, 07:11 PM
ZMANN's Avatar
He was asking on the different ways to run the 2x sub wiring to manipulate the OHM load
We Miss you Ronnie
ZMANN is online now
post #5 of 7 Old 03-31-2014, 08:24 PM
StrokinAlaska's Avatar
They are dual 2 ohm sub's. What ohm load do you want
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #6 of 7 Old 03-31-2014, 08:27 PM
Depending on what year they are will tell you their RMS wattage, that's what you match the amp to. So 1000 watt @2ohms and 750 @ 4ohms etc,etc. If they are the 13 and up they r 1000watt RMS, anything older is 600. So 1200 rms to 2000 rms go to hi you run a higher chance of toasting them!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #7 of 7 Old 03-31-2014, 08:29 PM
Series parallel them on a mono amp so you will be at 2 ohms final load!
Sorry I did this in 3 messages
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
