Permanent door ajar and non working locks - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-29-2014, 06:10 PM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
So today my power locks went out. Only thing that works on them is the illumination. No sounds or clicks or anything. They just dont work, on all the doors. At The same time, the door ajar light stays on.
Also my radio stays on even after opening door. Has 10minute timer though. Dome lights also don't come on until key is turned...
I tired pulling and checking all the fuses. All looked good. Pulled and placed the k126 relay back in and that didn't work either.
Also I did the whole "wd40 into the latches" thing and it didn't help at all either.
So what do I need to do or check? I'm leaning towards the vsm.
2002 F-250 XLT. TS 6 Pos. Chip, AFE Magnum Force Stage II Cold Air Intake, 5" Exhaust from turbo back. 07' Headlights, Custom Raptor Style Grille, 2012 Tailgate, Ranchhand Rear Bumper, 6" lift, 08 Dash Swap, 4x Infinity Kappas, JBL GT5-2402BR, A lot more to come.
TPlatt is offline
post #2 of 16 Old 03-30-2014, 05:29 PM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
Ok so today I took actuator out and it works just fine. I also tried taking and reconnecting the vsm and all plugs are secured. Idk what the problem is unless it's a faulty vsm.
TPlatt is offline
post #3 of 16 Old 03-31-2014, 06:36 AM
timmyboy76's Avatar
my door ajar stayed on. Sprayed some wd-40 into the little catch arm, protruding from extra cab door, on each side and been great for 2+ YRS
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 16 Old 03-31-2014, 07:03 AM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
i wish that had solved my problem...
TPlatt is offline
post #5 of 16 Old 03-31-2014, 04:04 PM
Solid98's Avatar
Quoted: 8 Post(s)
Spraying WD40 didn't work for me, either. I used my AE to find out which door lock switch was bad and paid a windshield shop $35 to change it out. I have the same problem with my door locks not working but that didn't fix it.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #6 of 16 Old 03-31-2014, 06:54 PM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
Yeah I'm going to get my vsm checked out tomorrow hopefully by the stealership.
TPlatt is offline
post #7 of 16 Old 04-13-2014, 01:37 PM
Question VSM ?
Can I ask what VSM stands for. Thanks
COP-OUT is offline
post #8 of 16 Old 04-14-2014, 03:32 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Vehicle security module. Only on 2001.5 and newer.
Using the AE for the switch test is the best thing for sure
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #9 of 16 Old 04-22-2014, 03:59 AM
Sorry to hijack your thread.
I have a 99 that the key fob will lock doors but wont open doors,(they open fine with key and mashing the unlock button). The dealership told me that the VSM was the problem, now I'm learning from Schlutzer that my truck doesn't even have a VSM?
bertieb is offline
post #10 of 16 Old 04-22-2014, 04:22 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Nope you have a GEM module instead. RKE module is what controls your locks anyway... that dealership is blowing smoke.
If your power locks work to lock with the fob, but not unlock, and they will unlock with the door button then I would lean to the fob itself being the culprit do you have a second one? If not they are really cheap to buy and you program a new fob yourself in a few seconds. (google it it's really easy).
