Sloppy gear shifter - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-21-2014, 06:51 PM Thread Starter
Sloppy gear shifter
Well my, new to me, truck has a bit of a sloppy shifter. Going into Reverse or Drive just requires a bit of playing around. Is the detents for this in the column or transmission itself. Hard to fix? Same for the ignition switch. I can shut off the truck and remove the key, open the door and I still get the chime. I have to put the key back in and jiggle it and remove the key. It's like it worn out. Replace?
Thanks.
jeffm920 is offline
post #2 of 8 Old 03-21-2014, 09:21 PM
Broken/cracked shifter tube or missing screw at the end of the shifter tube are the most common.
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
post #3 of 8 Old 03-22-2014, 01:53 PM
Solid98's Avatar
Quoted: 8 Post(s)
Search Youtube for "Ford Steering Column Loose Shift Rail" That video will show you how to replace/repair the shifter tube. Took me all of an hour to do it on my 99.5.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #4 of 8 Old 03-22-2014, 02:46 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #5 of 8 Old 03-23-2014, 08:30 AM Thread Starter
Ok, thanks.
92 F250, 7.3 PS.
jeffm920 is offline
post #6 of 8 Old 04-17-2015, 02:33 PM
heykw's Avatar
Are most of you replacing or repairing the shifter bushings?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #7 of 8 Old 04-17-2015, 02:51 PM
john galt's Avatar
Quoted: 1095 Post(s)
not sure if it is the same with the 7.3 as my early 04 but the stupid plastic connector that holds the shift cable in place on the trans falls apart (being plastic) and will cause exactly what you are describing. I had the same scenario and wound up "fixing" it with bailing wire and a couple zip ties and while i have the new piece to put in...i swear it is stronger this way than with the new linkage and the same stupid plastic clip
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #8 of 8 Old 04-23-2015, 02:26 PM
Solid98's Avatar
Quoted: 8 Post(s)
My shifter tube was fine so I just tightened up the torx bolts on the end, after applying lock tite, and replaced the shifter bushings. The motion of shifting in and out of gear just hacksaws the plastic bushings in half and they just fall out causing the slop. The bushings were less than $3 at Vatozone.
Solid98 is offline
