HIDs make high beams cut lights off - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-18-2014, 06:02 PM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
So I bought this truck little over a month ago. When I turned the high beams on the headlights cut completely off. When I pulled the light switch back and held high beams on the headlights don't change at all but remain on. He said ever since he installed the HID lights, it behaved like this. Any ideas?
2002 F-250 XLT. TS 6 Pos. Chip, AFE Magnum Force Stage II Cold Air Intake, Zoodad Mod, 5" Exhaust from turbo back. Halo-projection led headlights, Custom Raptor Style Grille, 66004b road armor bumper, smittybilt x-20 10k winch, 2012 Tailgate, Ranchhand Rear Bumper, 6" lift, 08 Dash and Column Swap, 08 mirrors, 4x Infinity Kappas, JBL GT5-2402BR, And a lot more.
TPlatt is offline
post #2 of 4 Old 03-20-2014, 09:01 AM
7.3pwrstrke's Avatar
They're not bi-xenon, aka low beam only.
Your headlight bulb has 3 wires going to it. High, low, and ground. When you push the switch forward, power is switched from the low to high. When you pull it back, I believe it gives power to both high and low (hence why nothing happens)
Mine are like this, it's $20 cheaper from DDM tuning and most other HID suppliers. Also easier than running a relay that ford vehicles typically require.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #3 of 4 Old 03-20-2014, 12:55 PM Thread Starter
TPlatt's Avatar
Quoted: 3 Post(s)
Ok I'm not big on lights. So I had no idea. Thank you thought for clearing that up for me.
TPlatt is offline
post #4 of 4 Old 03-26-2014, 05:22 AM
kbragg430's Avatar
If you want to buy a nice hid setup go to the retrofit source. Im about to do a complete projector retro on a set of harley lights
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
