Crew cab door rattle - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-15-2014, 12:00 PM Thread Starter
Quoted: 3 Post(s)
I have an 01 F 350 Crew cab I have a rattle when going over bumps. It sounds like the rear doors but not sure. It sounds like the latch is loose on the striker, is there anyone who knows a fix for this?
2006 F-350 Crew Cab Long Bed 6.0L
wags1992 is offline
post #2 of 5 Old 03-15-2014, 12:17 PM
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
Take a look at this to see if it could help.
Door Seal Mod
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #3 of 5 Old 03-15-2014, 03:28 PM
Quoted: 2 Post(s)
I went through this, I ran tubing in door seals, readjusted door strikers, shrink wrapped the rod inside the door for the locks, I was losing my mind! Then I tore the doors apart and found the little resisters for the door speakers had broken off and were rattling around in the bottom of the doors. So I soldered them back on and wrapped them in electrical tape so it won't happen again. Now I have super quiet doors with no road noise! Good luck hunting!
2000 f-250 superduty
leveled on 375/65/16 MTZ's 16x12 Classic 3,"X" code front leafs, afe stage 2 intake, 175/80 p.i.s injectors, 38R turbo, Adrenaline hpop,ITP return fuel sys with reg,
4" from turbo back, lentech built trans, 12 billet converter, DP tuner!!!
krs1r/t is offline
post #4 of 5 Old 03-15-2014, 06:02 PM Thread Starter
Quoted: 3 Post(s)
I am going to try the mod in the video, but I am going to try and use 3/8 round foam insulation I found at home depot. I am going to try it tomorrow I'll let you know how it goes.
wags1992 is offline
post #5 of 5 Old 03-16-2014, 04:50 PM Thread Starter
Quoted: 3 Post(s)
I did it. I like the way it came out the foam really holds up strong and creates a good seal for the doors but doesn't over do it to where you have to slam the door to close it. It was a little hard to install in the seal all I can say is a lot of lube. I did have problems with the foam breaking half way through. I'll I did was run my puller through one of the small holes and pulled the foam through the other way.
wags1992 is offline
