A/C only works sometime - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-10-2014, 06:16 PM Thread Starter
A/C only works sometime. By accelerating quickly I hear a thump (like a door closing) and then the a/c starts working. It works for some length of time. This is a reliable method, works ever time. Does not appear to be a vacuum problem because pump cycles as needed. 2001 f250 7.3 270K
mikejan1 is offline
post #2 of 2 Old 03-14-2014, 12:03 PM
Stroker7.3's Avatar
when you have the AC on does it blow warm air? Then sometimes blows cold air? if so pull the clutch off the ac compressor, remove the washer behind it and reinstall the clutch. worked perfectly for me.
2000 FORD F250 SUPERDUTY
Stroker7.3 is offline
