overhead counsel display not working - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-18-2014, 06:29 PM Thread Starter
Got a 99 f350 supercrew lariat,7.3,has the overhead counsel,the display dont work,any ideas where to start trying to look and see how to fix it.thanks,fuse relay?
bullrun is offline
post #2 of 9 Old 02-18-2014, 06:54 PM
Motomez's Avatar
I just had mine repaired from a guy from EBAY. For $30 he will re-soldier the diode back on the circuit board. works perfect
2002 PHP Hydra Chip, Banks Monster Exhaust John Wood Transmission 6.0 Cooler 06 front Axel Pure Performance 6 inch lift and 4 link 08 Rear springs Fox Racing 2.0 Piggy Back Shocks Raceline Renegade 8 wheels with 35 Toyo RT's Auto Meter Gages PSC Hydro Steering Dorman Bellowed up pipes Ford AIS 08 Tow Mirrors
Motomez is offline
post #3 of 9 Old 02-18-2014, 07:00 PM Thread Starter
info
Got a contact number
bullrun is offline
post #4 of 9 Old 02-18-2014, 07:13 PM
Motomez's Avatar
I have his number on my desk at work. I will send it tomorrow
Motomez is offline
post #5 of 9 Old 02-18-2014, 07:25 PM Thread Starter
thanks
Thanks,i would appreciate that
bullrun is offline
post #6 of 9 Old 02-18-2014, 09:27 PM
StrokinAlaska's Avatar
If u have a soldering iron u can do it yourself too! Pretty easy to do, hardest part is to pull it out, which still is just pulling it down.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #7 of 9 Old 02-20-2014, 11:52 AM
Motomez's Avatar
You can call Scott at 800 385-1984 for the repair
Dana
Motomez is offline
post #8 of 9 Old 02-20-2014, 02:46 PM
scagle1's Avatar
^ as previously posted , with a soldering iron it is an easy fix , there are a bunch of writeups with pics as well on the forum as well as several other places
Overhead computer Fix - Easy and it works
1999 Ford F350 4x4 - Overhead Console Repair
and on and on and on....
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #9 of 9 Old 03-02-2014, 08:14 PM
13fcolt's Avatar
I'm so glad some one posted this. Mine was not working and I hadn't even noticed. I've only had it a couple weeks now and have put most of my attention under it rather than inside.
So I took care of it today and this is what happened.
One of the 680's came off as soon as i touched it and the one right next to it was only attached at one end. Irritating little buggers to re-solder back in place. I would have preferred to use conductive glue but I could not find it until after I was done.
The repair works!!
Plugged it back into the harness to check things out and got happy green numbers. I also got a good idea as to what causes this to happen in the first place. While I was holding like this, I pushed the buttons to make sure everything was in order before putting it back together and the circuit board directly behind these resistors got hot. Heat was enough I couldn't hold it with my finger on that spot anymore. Pretty sure these go directly to the display since as long as the display was off, no heat.
I'm hoping someone around here is an electronics wiz and can suggest an alternative component or solution for a better fix.
I'm a Diesel man. I care about torque, boost, and EGTs. The truck is just an accessory to carry my engine around.
13fcolt is offline
