99' tan interior paint? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-04-2014, 08:01 PM Thread Starter
I finally broke down and ordered some gauges, but I need to paint the pillar pod to match my 99' tan interior. Does anyone know what color I need and where I could get it?
99' Powerstroke is offline
post #2 of 6 Old 02-05-2014, 09:18 PM
kbragg430's Avatar
http://www.strictlydiesel.com/p-2782...tch-paint.aspx
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #3 of 6 Old 02-05-2014, 09:33 PM
daddyusmaximus's Avatar
Quoted: 12 Post(s)
My '99 also has tan interior... but no sticker in door jam.
99 F-250 Super Duty, 4X4, CCSB.
AKA: The Liberty Wagon.
daddyusmaximus is offline
post #4 of 6 Old 02-06-2014, 02:24 AM
SEM makes a really good paint that I used and it came out great think it is med parchment
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #5 of 6 Old 02-08-2014, 08:18 AM
chrgd2000's Avatar
Look here.. I would use the SEM. It would match the best. Ford Interior Trim Codes
--7.3
chrgd2000 is offline
post #6 of 6 Old 02-15-2014, 05:59 AM
delta99's Avatar
I used krylon flat tan color. My tan interior has at least 3 different shades of tan from the factory, so it doesn't look out of place. And it was like $4
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
