Instrument Cluster 1999 F350SD - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-22-2014, 08:03 PM Thread Starter
I will change the cluster lights to blue LEDs.
Some "leftover" questions:
How do I get the needles "clear" instead of red?
How to remove and reinstall the needles the "right way" (e.g. calibration)
Thanks
1999 Ford F-350 SD, CrewCab, Dually, 2WD, 7.3 Turbo, Superchip, Engine Brake, 180,000 km
1993 Ford F-350 Centurion, CrewCab, Dually, 2WD, Long Box, 7.3 IDI w/o turbo (), lots of lights, 171,000 mls
1996 Layton 5th Wheel, 34ft, 2 slides, 12,000lbs
1995 Chevy Silverado 2500, ext. cab, short box, 4X4, 350, 330,000km
donmi is offline
post #2 of 2 Old 01-24-2014, 05:13 AM
Houstonvett's Avatar
Removing the needles is best done with 2 flat objects such as butter knives and use both objects to pry up the needles gently on both bottom sides of the needle. To reinstall correctly, you will have to reinstall the gauge cluster, plastic clear cover off, of course. Put the truck in the run position with the ignition key. Once this is done you can push the needles down in their proper starting position. Getting the needles from red to clear I have never worried about that and just left them as they were. Good Luck on your project.
Houstonvett is offline
