Interior/Exterior lighting - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-14-2014, 06:26 AM Thread Starter
i dont usually come here and ask for help unless ive exhausted all my options and read pages of things.. my problem is similar to others although none have had quite as many issues all at once.
99 ford f350 7.3 XL
First, my problem is with my interior dome light.
The dimmer switch works to dim the dash, but when i put it all the way to where it will click to turn the dome on it doesnt. I here a click in the fuse panel but no dome action.
The dome lights work if i turn them on at the light by hand
No lights come on inside the truck when any of the doors are opened
The rear cab light that doubles as a break light never functions, only the brake section works when i hit the brakes it lights up red.
Door locks all work, no problems with headlights, radio, dash etc.
HELP
awdtsi98 is offline
post #2 of 3 Old 01-14-2014, 12:46 PM
Quoted: 6 Post(s)
The light that comes on when you open the doors and when you hit the switches are different bulbs. The bulbs for the entry lighting could simply be burnt out. I would check that first. Same for the exterior cab light. If that doesn't do it then you might need to drop the headliner and take a look to make sure the wiring hasn't been damaged.
Will335i is offline
post #3 of 3 Old 02-08-2014, 11:27 PM
StrokinAlaska's Avatar
Follow the Black/Lt Blue wire found in your driver kick panel in the taped loom. That's the dome light wire. It should be 12v while your door s open and when your dimmer switch is rolled up to engage the dome lights
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
