subs and amp in ex. cab? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-11-2014, 09:01 AM Thread Starter
Powerstroke_21's Avatar
I have a late 99 f350 and want to put subs and an amp in it but I can't find any boxes that fit under the back seat. Has anybody else put subs in the cab of a late 99 ex. cab? If so where did you find a box that will fit and what size subs did you go with?
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #2 of 13 Old 01-12-2014, 06:47 AM Thread Starter
Bump
Sent from AutoGuide.com App
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #3 of 13 Old 01-13-2014, 11:12 AM Thread Starter
Anybody?
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #4 of 13 Old 01-13-2014, 11:15 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 494 Post(s)
Would have to be custom made dude. And you probably couldnt go any bigger than some shallow 10's. 12's would probably stick out. My kid took out the small seat (if yours had that) and just threw a 15 in it! Good Luck
@loxdce
LoxDiesel is offline
post #5 of 13 Old 01-13-2014, 01:08 PM Thread Starter
Alright thanks man!
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #6 of 13 Old 01-14-2014, 05:29 AM
i have a 12 inch single square ported enclosure that sits on my back seat behind the drivers seat, with an amp below it on the ground. Even if you have a custom box made, the amount of money, time, your going to spend to find something that shallow wont be worth the sound increase. I would either rock a 12 on the seat, or have your amp and a shallow sub mounted behind the backseat. If you look the back of the seat flips down and theres enough room in there to mount an amp and shallow sub. Its clean, and hidden. But the choice is yours.
awdtsi98 is offline
post #7 of 13 Old 01-14-2014, 05:59 AM Thread Starter
okay, thanks for the help. I think I may just go with a single square ported 12" box and put it on the floor in the back behind the jump seat. that way i can still fit 3 people in the back, but the middle person will have to kinda straddle the box
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #8 of 13 Old 01-15-2014, 04:47 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I have a single 12 in a box behind my seat. Have the seat folded up.
There is also this box
Ford F-250 / F-350 Extended Cab 00-13 MTX Thunderform Subwoofer Box
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #9 of 13 Old 01-15-2014, 04:58 PM
Vannnce's Avatar
Quoted: 13 Post(s)
i have my amps mounted behind the rear seat, and a single 10 under the "little" seat
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #10 of 13 Old 01-15-2014, 05:08 PM Thread Starter
See I have 2 12" subs and amp already and was thinking about going with the box that goes in the back on the floor behind the jump seat. Crutchfield has one that looks like a factory box. Or just getting a shallow box and sub to slide under the the jump seat. I'd like to save as much money as possible
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
