Frozen door seals - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-25-2013, 11:33 AM Thread Starter
Frozen door seals
Every time its cold out, my doors stick closed. The weather stripping around the doors including the tailgate freeze and I can never get the doors open.
It is something about the water/snow falling down in the top of the doors and then it freezes their. Also I get leaks around the bottom of the doors where my carpet is a little damp.
Does anyone else have problems with this? I've never had a vehicle that the doors stick this bad. Usually it only happens after washing in the cold weather, but this happens most everyday when it is 0 degrees. Any way to fix?
99' F-350 CCLB 92,100 miles ▬ 05 headlights • 4" exhaust • 6637 • Gauges • F650 dash • blue LED interior • HID Headlights & offroad lights • 20" LED lightbar • PHP Hydra • 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #2 of 2 Old 12-25-2013, 11:54 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I eventually rip off the weather stripping on my work truck from this very thing. The only thing that I ever found that helps is to spray the rubber with WD40. Seems to do pretty good.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
