Stock to Double DIN Radio - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-21-2013, 08:50 AM Thread Starter
Hello all! I searched the threads for an answer to this, but couldn't find what I was looking for.
I have an 02 F350 with the stock CD/Cassette radio unit. I've read that if you install a double DIN unit you will need to do "some modding". How much modding?
I HATE dash work, I'm more of a nuts and bolts person. Some folks who like dash work might think something is simple, where I would consider it an exercise in frustration.
Does anyone have good intel on how difficult the mods would be to put in a double DIN unit in the stock opening?
I'm not doing any other work on amps, speakers, etc. I never turn it up beyond a volume that would inhibit conversation in the cab anyway, so stock speakers is just fine with me. But that cassette slot staring at me says old. Really, all I want is a unit with Bluetooth to connect my phone to.
Thanks all for any info on the mods needed to install a double DIN unit!
Generok is offline
post #2 of 6 Old 12-21-2013, 08:54 AM
STANGMAN893's Avatar
You have to trim the dash bezel around the radio. The new unit will snap onto the bezel around the radio.
STANGMAN893 is offline
post #3 of 6 Old 12-21-2013, 09:32 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I havent done it yet but I did research on it... it seems fairly painless ( I too hate interior work even though I've rewired my entire interior).
You buy a mount kit made for these trucks ( $20 or so) and get the dremel out then you're done
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 6 Old 12-21-2013, 09:52 AM
alaskan155's Avatar
Quoted: 65 Post(s)
option 1
right now you have a din and a 1.5 so you just need to open the bottom of the hole and the top of the hole a little bit, a dremal with a sanding wheel will work. you basically just grind untell the new cage fits.
option 2
swap in a 05-07 upper dash/entire dash. a little harder but the factory din is a double din and the modification are behind the panal(if you just swap the upper part.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #5 of 6 Old 12-21-2013, 12:55 PM Thread Starter
Thanks all, sounds easy enough. If I had a garage long enough to park all 21.3 feet in, I'd do it next weekend. Otherwise it'll have to wait until I go to the Auto Hobby Shop for oil change, or spring in the driveway.
Generok is offline
post #6 of 6 Old 12-21-2013, 03:14 PM
Quoted: 5 Post(s)
I did it to my 99 a while back. From what I remember, it was some minor bezel sanding, and a good whack with a mallet tot he metal support around the dash and it slid right in.. Pretty easy mod if my memory serves...
UrbanKnight is offline
