Information center? doesnt work - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-18-2013, 12:14 PM Thread Starter
On my '01 F250 the what I would assume is called the "driver information center" between the sun visors does not work. I bought it and it did not work and didnt know if this was a common occurrence like the door lock actuators that I just recently fixed. I'm not sure the exact name of what its called to do a search, so I figure I'd ask to see if there is an easy fix.
Thanks in advance.
2001 F250 Lariat 7.3L. 4" MBRP exhaust, 2" leveling kit, 35" tires, Diablo tuner
str8flexed is offline
post #2 of 8 Old 12-20-2013, 09:34 AM Thread Starter
anyone?????
post #3 of 8 Old 12-20-2013, 10:38 AM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
http://www.ebay.com/itm/FORD-SUPERDU...fb8c6c&vxp=mtr
They fixed mine
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 8 Old 12-20-2013, 10:41 AM Thread Starter
Originally Posted by gomer pyle View Post
Awesome, I'll have to check them out.
Thank you.
post #5 of 8 Old 12-23-2013, 08:52 PM
StrokinAlaska's Avatar
Your over head readout?
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #6 of 8 Old 12-24-2013, 05:46 AM Thread Starter
Yes, I didn't know what it was called
post #7 of 8 Old 12-24-2013, 08:33 AM
Pull it out n on the board usually a solder joint it loose. i heated mine up n wala she worked again! East fix took 15 minutes
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
The Following User Says Thank You to StrokinAlaska For This Useful Post:
str8flexed (12-26-2013)
post #8 of 8 Old 12-26-2013, 05:00 AM Thread Starter
Pulled the board out, and behind the readout screen 890 was slightly off the board. Pushed it back in, and heated it back up, and voila, it works now!
Thanks for the easy fix!!!
