Erratic Tach - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-03-2013, 05:12 PM Thread Starter
Quoted: 4 Post(s)
Question Erratic Tach
Tach started being erratic with needle not making sense.
I discovered by accident that with the lights on I can move
the dash lights dimmer switch and mover the tach needle!
I essence I can move the tach needle up and down by rotating
the dash dimmer dial.
Any ideas???
Thanks
2000 F350 Automatic 7.3L
Sundance58301 is offline
post #2 of 9 Old 12-04-2013, 08:37 AM
Ol Red's Avatar
Sounds like short in or around the gauge cluster. Did you have anyy work done recently. Might have to check the wires in it.
99
F250 Super Duty 7.3L
Edge Products tuner, 4" exhaust under the cab, 37" Military tires, work in progress
Ol Red is offline
post #3 of 9 Old 12-04-2013, 03:14 PM Thread Starter
Quoted: 4 Post(s)
No work done,,,,,,,,,,
Hoping someone has had that issue with a magic fix
post #4 of 9 Old 12-04-2013, 03:36 PM Thread Starter
Quoted: 4 Post(s)
i get the short idea and would agree, but the correlation
with the dash dimmer dial is weird.
post #5 of 9 Old 12-05-2013, 05:29 AM
Ol Red's Avatar
Could be in the cluster itself. All I could say is test it with a junkyard cluster. If it still does it you know its further bacck.
99
Ol Red is offline
post #6 of 9 Old 12-06-2013, 10:38 AM
basicbajax's Avatar
Mine did the same at some point. It turned out to be a leaky windshield that had eventualy corroded the actual cluster causing all kinds of weird things. A new cluster fixed the problem. Got one with a 100,000 less miles on it to boot...
I used to think high mileage was a bad thing, but its a badge of honor on my F250 Powerstroke.
basicbajax is offline
post #7 of 9 Old 12-20-2013, 09:53 AM Thread Starter
Quoted: 4 Post(s)
So how hard is it to switch out cluster??
post #8 of 9 Old 12-20-2013, 10:23 AM
basicbajax's Avatar
Once you learn how to pop the dash off and getting the cluster in your hands it aint to bad...
post #9 of 9 Old 12-20-2013, 11:37 PM
Ol Red's Avatar
dash is really simple. pop out the headlight switch, pull at the seam on the dash above the steering wheel, unplug the radio and cig light, under cluster and replace and repeat in opposite order to reinstall. just had to do this to replace the turn signal switch.
99
Ol Red is offline
