Windows, and blower motor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-28-2013, 12:20 PM Thread Starter
Got a 99 powerstroke with 99 problems apparently everyone likes to hide stuff when they sell it
Blower motor only works on high, is this a switch or the blower motor itself?
Also windows won't go down, it's a crewcab and only the passenger rear will go down
Relay works, you can hear it click
The kicker is you can roll the windows down from any switch
cyclegrip is offline
post #2 of 4 Old 12-01-2013, 03:41 PM Thread Starter
Any ideas?
post #3 of 4 Old 12-01-2013, 04:53 PM
Eco Taxi's Avatar
Check into your blower motor resistor
$20 part IIRC, I changed mine awhile ago because mine only worked on high. Fixed my issue
heater quit working
HVAC blows on HI only?
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #4 of 4 Old 12-02-2013, 06:07 AM Thread Starter
Thanks! I'll check into that
Also I have a huge problem that just occurred, my ECM somehow comes disconnected?
My wait to start light won't come on and my edge won't hook up says ECM cannot be found or something like that, truck will just crank won't start
