Any ford key fob locks my truck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-14-2013, 10:10 AM Thread Starter
kclough's Avatar
Exactly as title says. I bought my 02 250 crew cab lariat two years ago and wireless entry never worked. I thought no big deal, well I found out any ford remote can lock my truck but cannot unlock (thank god). When it pick s up a signal the alarm goes off even when i unlock the truck with my key. It will also go off if you open the door from inside with the motor on. Only way to reset it is to disconnect both batteries. So my question is where is this receiver located and can I just unplug it?
kclough is offline
post #2 of 5 Old 11-14-2013, 07:06 PM Thread Starter
kclough's Avatar
Bump anyone have an idea
kclough is offline
post #3 of 5 Old 11-14-2013, 07:25 PM
drivininidaho's Avatar
Quoted: 69 Post(s)
I'd say take it to a dealer and maybe have them reset it. It may do the trick.
sent from everywhere...
Lyndel
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #4 of 5 Old 11-15-2013, 05:08 AM
Quoted: 3 Post(s)
Look under the steering wheel behind the removable panel. You should have a control box under there and you can unhook it. I doubt it's tied into an immobilizer but if it is, you would need to have that disabled first
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #5 of 5 Old 11-15-2013, 05:30 AM Thread Starter
kclough's Avatar
Alright thank you I'll let you know what I find out
kclough is offline
