changing the light color in the gauges cluster? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-11-2013, 05:08 AM Thread Starter
ZackMicF's Avatar
Quoted: 27 Post(s)
Question changing the light color in the gauges cluster?
can changethe light color in the gauges cluster?
i thik the green is a little out dated, i want to change evrything to blue
i was just going to solder ing soem LEDs in all the buttons on the doors and heater AC knobs, i was wondering about the gauge cluster?
i seen some blue LED bulbs on ebay and they look like they just plug right in
any one done this before or hvae any advice or pics?
ZackMicF is offline
post #2 of 3 Old 11-11-2013, 10:53 AM
CSIPSD's Avatar
It can be done, but its very hard to do. Not a bulb swap kind of thing. The color of the gauge face comes from the backing, not the bulbs.
In order to do it you have to strip off all the green, then replace the bulbs with blue LED's.
I caution you however.
I used to have all my gauge faces blue, but over the course of several years I noticed I would get headaches driving at night, and my night vision decreased.
Went to my DR about it and he suggested turning my gauge lights off for a few weeks.
Low and behold my headaches went away. I switched all my gauges over to green and no issues.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 11-11-2013, 11:09 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I get those damn headaches too, right behind the eye. Real b----es but if you want that blue back, what im going to do is scrape the green off and repaint some transparent paint(in my case amber), that way you can retain the dimmer function for those late night long hauls
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
