A/C Stuck on? Now Heat stuck on? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-29-2013, 08:14 PM Thread Starter
I got a funky one boys... When I first bought my truck I couldn't get the heat to work.. figured I maybe needed heater core. played with the cold/hot knob a little popped the hood and jiggled some stuff and then all of a sudden my heats working great.. now my heat is stuck on max heat( live in southern Lousianna) but no A/C. When I put it on MAX A/C it is still very hot coming out of the vents.. All of my controls seem to be working(floor, face vents ETC) just no climate control.. Any ideas?
99 F-350 6sp SRW SLT 118K SOLD
2008 F-250 Lariat 6.4 140k
Eatroost450 is offline
post #2 of 5 Old 10-29-2013, 08:15 PM Thread Starter
BTW A/C blew cold before I got the heat to work.
post #3 of 5 Old 10-31-2013, 09:40 AM
Quoted: 3 Post(s)
short somewhere or bad switch. I had the same issue in my fire engine, if its not set in the right spot when I turn the batteries on I get whatever it was set at no matter how I change it..... Sucks to have full heater in 115* summer weather!!!
The engine is an international cab and chassis so I know most of the Ford things are the same, mine needed a whole new switch set up (all 3 had to be replaced)
P-rot is offline
post #4 of 5 Old 10-31-2013, 08:41 PM
I might have the same issue. I have a/c and no heat
2005 f250 extcab long bed 6.0 torqe shift (SOLD !!!)
2000 f250 7.3 powerstroke automatic ccsb virgin
05powerstroker is offline
post #5 of 5 Old 12-15-2013, 03:36 PM Thread Starter
I figured it out gentleman, If you drop your glovebox down and look inside you can see your electronic blend door actuator. Either its the actuator or the actual blend door. Refer to here:
If its not the actuator.. here is a cheap solution called "heater treater
Ford F250+ - F250+ - Ford
