Help jump set to center console install - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-09-2013, 07:22 PM Thread Starter
hellraiserford's Avatar
Feedback Score: 7 reviews
Send a message via Yahoo to hellraiserford
Went from a jump seat to a center console set up. Went to ford and got the inserts for the floor board to mount the console to. Problem is cant get the inserts to stay in the floor board. Is there a trick to it or do I have to glue/ jb weld them to floor board? Just let me know what yall think. Thank you
hellraiserford is offline
post #2 of 7 Old 10-22-2013, 06:06 AM
Hey not sure about how to get the inserts to stick in the floor. I will let you know as soon as I pull my console out. Do you still have ur jump seat I am looking for one have a trip next summer want to take 6 people. Thanks
F2504x4 is offline
post #3 of 7 Old 10-22-2013, 06:45 AM Thread Starter
I still have the jump seat, but leather was damaged due to a break in. So not sure if that would do you much good.
post #4 of 7 Old 10-27-2013, 12:22 PM
Rear hardware/mounting bolts
Hello hell raiser I got lucky and found a jumpseat for my truck but it did not come with the rear hardware to mount it. Do you happen to have your rear hardware to mount it to the cab
F2504x4 is offline
post #5 of 7 Old 10-28-2013, 09:38 AM
Jump seat hardware
I sent you a pm. Thanks
F2504x4 is offline
post #6 of 7 Old 10-28-2013, 09:41 AM
Macon's Avatar
I always assumed the console was mounted similar to the jump seat. Are there any pop-outs in the floor board for additional bolts?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 7 Old 10-28-2013, 09:55 AM
I have not actually completed this project as I need the hardware to mount my new jump seat. The front of the jump seat attaches to where the front seat mounts are. Where the rear legs attach is where it gets tricky I have been told that there are plugs you pop out and and you use those holes to attach the rear of the seat. My truck a 00 cc f250. I am basing this hardware list off a 01 f250 xcab with a jump seat. The driver rear requires a stud and a nut with a plastic cap. The passenger side has a hex bolt similar to the bolts used to hold the front seats in.
F2504x4 is offline
