AC outlets in cab - Ford Powerstroke Diesel Forum
post #1 of 21 Old 10-02-2013, 05:46 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
AC outlets in cab
Hey guys im installing a couple AC outlets on the dash and my question is how much power does a typical inverter use when not actually being used? Should i use a GPR-like relay to power the inverter while the truck is on or could i just wire it straight to the battery? Ideally id like it to be hot at all times so i dont have to have the keys in to use it. Im going to mount the inverter behind the dash so i wont be able to switch it on or off by the inverter.
Heres what im doing
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 21 Old 10-02-2013, 05:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive got a 1500 in the cab of my truck and a 3000watt in the back. I can power up just about anything I need and I can leave the 1500 on 24/7 with no issue's.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 21 Old 10-02-2013, 06:00 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Cool i just have a modest 750 just to power small tools and charge phones or things like that.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 21 Old 10-02-2013, 08:51 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
This got to buggin me so I had to take a look, I got a 5k in the back. It does a good job of running a small microwave. You can only eat cold lunch's for so long....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 21 Old 10-02-2013, 08:55 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Funny thing is with all the things i add to my truck my parents joked and said soon ill be adding a microwave to the truck and i thought that was a great idea.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 21 Old 10-02-2013, 01:36 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive got the little $70 microwave from wally world and they last me about a year and a half before they give up. Its not bolted down. Its just wedged in so that poor thing gets beat up something fierce. But it keeps on tickin.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 21 Old 10-03-2013, 06:01 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Nice i have no reason for a microwave but if i did id do the same as you. But i got them imstalled ill post some pics tomorrow
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 21 Old 10-07-2013, 10:15 AM
Eco Taxi's Avatar
So I assume your just gonna run this straight off the battery? Lemme know how this all works out, it's a good idea
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #9 of 21 Old 10-07-2013, 10:24 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sorry i forgot to get pics but it worked out great, i just ran it straight from the battery with 4 GA wire and put the inverter behind the panel that i put the outlets on, its about the only place behind the dash that has room
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 21 Old 10-07-2013, 10:47 AM
drivininidaho's Avatar
Quoted: 86 Post(s)
im def thinking of doing this in my work truck, so i can charge tools and what not.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
