2003 F350 OE Radio Removal - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-27-2013, 05:00 AM Thread Starter
I have a 2003 F350 and it still has the OE 6 disc radio in it. The CD portion does not work and I would like to change it out without paying someone as I believe I can get the radio cheaper than paying someone to install it. Anyways I have the removal tool but when I insert the tool there is no "click" and the tool pulls out when I pull outward to try and remove the radio.
Am I doing something wrong. My neighbor mentioned that the clips that lock the radio in place may be broken. If that is the case is there a way for me to remove the radio without paying someone.
Any help is greatly appreciated.
Thanks
Mark
firstcapitalfirearms is offline
post #2 of 5 Old 09-28-2013, 04:01 AM
heisman01's Avatar
Quoted: 52 Post(s)
You have to jam those prongs all the way in and pull on the radio itself sometimes. Also you can just pop that part of the dash off it doesn't take much time at all.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #3 of 5 Old 09-28-2013, 06:14 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I've never had much luck with the prongs. On these trucks just pop out whole piece the surrounds the radio and gauges. Then you can even just use your fingers to push the clips in
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 5 Old 09-28-2013, 06:19 PM
Lilfarmrboy's Avatar
It takes a few tries... also you have to pull the U shaped removal tools outward (away from the radio, like you are spreading them) for them to lock (I believe). At least that's what I had to do to my 04. Once they do lock the radio comes right out but like I said took me a few tries to get them to lock.
Lilfarmrboy is offline
post #5 of 5 Old 09-28-2013, 06:22 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
what he said ................you have spread the 2 tools while pulling out.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
