Gauge cluster bulb replacement - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-20-2013, 06:44 PM Thread Starter
So I have the gauge cluster out which was not to crazy difficult. Getting the bulbs out however seems impossible. There are these little black sockets that should turn I assume. But for the life of me I can't make them turn. My fingers hurt from trying. Turning to you guys for help before I destroy this thing. Is there some trick to this? I have attached a picture. Hopefully it works.
*edit
See below for how I got it to work.
2001 F-250 7.3 2wd
3/5 DJM drop, AIS Intake, Strictly Diesel Ported Housing, CFM Boots, Banks Exhaust Brake, 4" Banks Straight Pipe, PHP Phoenix Chip, Tru-Cool 40K Trans Cooler, KCM HPX, Autometer Ford Match Gauges (Boost, Trans Temp, Pyro), International Up-Pipes
dante81_98 is offline
post #2 of 11 Old 09-20-2013, 06:57 PM
chancelor's Avatar
i replaced some of mine with a 1/4 turn to the left
2006 F350 4X4 Lariat... Just getting started with this one... afe air intake, edge juice platinum with attitude, coolant filter kit, high idle switch added, blue spring conversion Fan clutch switch, daystar leveling kit, zoodad, a few extra lights, custom gooseneck hitch and air bags on the rear
chancelor is offline
post #3 of 11 Old 09-20-2013, 07:35 PM Thread Starter
Yeah, but they won't turn. I am going to have to turn them with a wrench to get some leverage, but am afraid I am going to break it.
2001 F-250 7.3 2wd
post #4 of 11 Old 09-21-2013, 01:01 PM Thread Starter
So I got them out, but they were so hard to turn that I had to use a wrench to get some leverage. I put in some led lights from AutoZone. Very happy with them. Glad to be able to see all my gauges at night.
ID:	171241   Click image for larger version
ID:	171249   Click image for larger version
ID:	171257   Click image for larger version
2001 F-250 7.3 2wd
post #5 of 11 Old 09-21-2013, 07:04 PM Thread Starter
And here are the results. Super happy with these bulbs.
2001 F-250 7.3 2wd
post #6 of 11 Old 09-21-2013, 07:11 PM
chancelor's Avatar
i think i have to go get some bulbs tomorrow! that looks good!
post #7 of 11 Old 09-21-2013, 07:24 PM
theplumbingmedic's Avatar
Looks great
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #8 of 11 Old 09-21-2013, 07:41 PM Thread Starter
Thanks guys. Here is a better picture.
2001 F-250 7.3 2wd
post #9 of 11 Old 09-22-2013, 07:10 AM
How much did the bulbs run you? And how many are there in the cluster? Thanks
bleedfordblue is offline
post #10 of 11 Old 09-22-2013, 09:28 AM Thread Starter
They were $10 a piece and there are 5.
2001 F-250 7.3 2wd
