Buzz at start position - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-20-2013, 02:34 PM Thread Starter
carazola's Avatar
Getting a buzz sound when key turned to start position, slow turning over??? What's the deal
Sent from AutoGuide.com App
carazola is offline
post #2 of 8 Old 09-20-2013, 02:38 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What have you checked so far.... Batteries, alternator, starter... Got give us something to start with besides buzzing and slow crank
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 09-20-2013, 02:41 PM Thread Starter
carazola's Avatar
Buzz is in dash, just started today! Thinking something with ignition
carazola is offline
post #4 of 8 Old 09-20-2013, 03:05 PM
Quoted: 8 Post(s)
I've had relays go crazy before and do this very same thing... I'd try and track down where the noise is coming from.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 8 Old 09-22-2013, 06:30 AM Thread Starter
carazola's Avatar
Thinking the buzz might not have any thing to do with slow turn over. Battery gauge dips way down when starting, thinking one bad battery. Buzz coming from middle dash
carazola is offline
post #6 of 8 Old 09-22-2013, 07:49 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
First, so you know exactly what the batteries are going "down" to, put a meter on the system (use the in-cab "outlet" maybe), and see where the voltage drops to when cranking. Next, is it buzzing in the Run (key-on) position too? If so, see if turning on the Hazards or Turn Signals stops it.
NoRalPh is offline
post #7 of 8 Old 09-22-2013, 07:59 AM Thread Starter
carazola's Avatar
The buzz sounds like a tattoo gun and only lasts for a second when key is in on position not when starting the engine
carazola is offline
post #8 of 8 Old 09-29-2013, 05:21 PM Thread Starter
carazola's Avatar
Update:
One bad battery connection causing both buzz and slow crank!
carazola is offline
