diy sound proofing cab - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-31-2013, 08:06 PM Thread Starter
camsmell's Avatar
I was just wondering if anyone has tried using something like house carpet pad or anything similar under the factory carpet and behind the dash to help make the cab quieter I have plenty of spare time and can the pad for free so I was just wondering if it could work?
99.5 F250 full force stage II, riff raff frx hpx, T 500, 6637 mbrp stainless 4", DP Tuner, Isspro boost pyro trans, 4" lift john wood vb, 38r, coolant filter, ccv mod, cooling mist stage I, non ebpv pedestal
camsmell is offline
post #2 of 7 Old 08-31-2013, 08:53 PM
codyryan07's Avatar
I don't see why it wouldn't work, but have you seen what the pad looks like under old carpet? I honestly wouldn't want any of that gunk buildup in my truck, especially driving down dirt roads and what comes off your feet.
Check out some of the sound proofing materials and compare. I think lizard skin is one of the higher liked ones right now.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #3 of 7 Old 09-01-2013, 12:21 AM Thread Starter
camsmell's Avatar
I havnt had the carpet out of my ford but I had it out of my 07 mega cab 5.9 and it wasn't bad at all I was just wondering for the budget build kind of guy. maybe I should think of trying to doing a wright up of how it works out and holds up for the average guy.
camsmell is offline
post #4 of 7 Old 09-01-2013, 02:24 AM
BIG Laing's Avatar
Dynamat is out of the budget?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 7 Old 09-09-2013, 11:20 PM
I had some window wrapping tape left from the project and after chatting with my buddy who own an audio shop, I was told that my tape should work just fine. I came across 12"x66' rolls sold at local Dunn Lumber @ $50 per roll. One roll was enough to do the floor, rear doors, and back of the cab. After that I came across some carpet pad used on residential floor installation that I thought would work just as well with some spay adhesive, rear doors are no longer rattle as much and it is much quieter, since I have straight 4" pipe, I have notice a huge difference.
This just my 2c
Next month I will be covering sealing, and front doors along with new door seals, I expect big difference as before.
djpaul is offline
post #6 of 7 Old 09-10-2013, 04:46 AM
basicbajax's Avatar
Home depot duct insulation with sticky on one side and foil on the other side. It cheap and works good.
I used to think high mileage was a bad thing, but its a badge of honor on my F250 Powerstroke.
basicbajax is offline
post #7 of 7 Old 09-11-2013, 10:36 AM
Powerstroke Junkie
NCHornet's Avatar
If you are going to pull the carpet use a product designed for the job, the results will be worth it.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
