Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 10-19-2006, 12:48 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Gauge Cluster
Does anyone know if it is possible to change the stock 2000 gauge cluster with on from an 02-04. is the the same connector for the board in back or a completely different wiring harness. Thanks
Old 10-19-2006, 03:17 PM
Maintain Maintain is offline
13.0 @ 102
Send a message via AIM to Maintain
While I would assume the cluster would fit I do know that an 2002+ will NOT work with yours because they changed the gauges around and added an idiot light Trans Temp sensor.
Old 10-19-2006, 03:35 PM
Jon Jon is offline
DO YOU KNOW WHO I AM?
Also
If I remember the 2000 doesnt have a digital odometer.
Old 10-19-2006, 03:40 PM
Logan Logan is offline
The Fat Mod
Nope, sure don't. Mine is the 2000 and it rolls around and around.
Old 10-19-2006, 04:12 PM
I know they changed them. I had an 02 and liked the gauge configuration better. Just curious to know if they would work in a '00 without having to change the harness.
Old 10-19-2006, 04:13 PM
13.0 @ 102
It is doable, I know someone who took gauges from a 2003 and put them in his 1999. BUT there was aLOT of work entailed and he was a ford techie... basically his truck was soooo far from stock I'm sure the only stock parts on the truck were the body panels !!!
It's not worth it if you just like it better.
2002 was when Ford switched over to a Digital O/D and they also added sound insulation in the cab.
Old 10-19-2006, 04:38 PM
Jon Jon is offline
The big problem
is with the newer ones you have to program them with our computers. There is some module configuration that needs to take place.
Old 10-20-2006, 07:07 AM
ok thanks guys
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
