Door won't open - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-15-2013, 04:01 PM Thread Starter
7 3 Powerstroke's Avatar
Unhappy Door won't open
So I have done the tin foil trick for all of my door lock actuators, and they all worked fine...for a moment. About a week ago my back drivers side door decided to act up. Apparently I tightened the screw too much and it wasn't holding the gears into place so they kept slipping. I tried to fix this (which I wasn't able to) and ran into a major issue at the end of my project. I guess I didn't put the door back together right and now it won't open.
I'd like to know if there is a way to get the door open so I wouldn't have to take apart the door inside the cab. What would be the best and easiest way to get it open?
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #2 of 6 Old 08-15-2013, 04:44 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
The linkage must not be hooked up, your going to have to take the door panel off to correct the problem any ways so get to it. You don't want to try to open it and break something , so take it apart
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 6 Old 08-15-2013, 06:08 PM Thread Starter
I know I'm gonna have to take it apart, but didn't really want to do it from inside the cab because it'll be a pain in the @$$.
post #4 of 6 Old 08-15-2013, 06:10 PM
Quoted: 818 Post(s)
You can pop the door open from the inside when u pull the panel.
Corey@CNCFAB is offline
post #5 of 6 Old 08-15-2013, 06:53 PM Thread Starter
Do I just have to push down the latch? Or what?
post #6 of 6 Old 08-16-2013, 05:28 AM
Quoted: 818 Post(s)
Honestly I can't remember. Its been two years ago when I got stuck inside my truck. Long story. Rotflmao. I think you may have to pull on one of the linkage rods that overcomes the lock and the door latch.
