Will 04+ Harley seats fit my 00? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-14-2013, 03:13 AM Thread Starter
As the title mentions, i am looking to put some leather seats in my 00 CCSB. I prefer getting ford factory seats vs the re upholstering of the current ones. The seats i am looking at have two captains chairs, center console, and bench 60/40 for the rear plus the door panels. Will this be a direct drop in fit for my truck? If not, what will i need to do? I am assuming the seats will drop right on to the bolt locations, but the wiring could be a bit sketchy. Thanks in advance
buckwheat762 is offline
post #2 of 3 Old 08-15-2013, 10:58 AM
alaskan155's Avatar
Quoted: 65 Post(s)
if your current seats are powered then the wiring is there, if not then you have to run new power leads to the new seats.
and the 04 interior is the same as the 00 so everything should bolt in,
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 3 Old 08-18-2013, 07:14 AM Thread Starter
i have a power drivers side, but not passenger side. do you suppose the wiring is there for the passenger but just under the carpet?
my wife vetoed the seats for now, but i am going to give it some time and then see if i can squeeze it through.
