interior makeover - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-13-2013, 07:24 AM Thread Starter
metalman7.3's Avatar
interior makeover
Im redoing my interior, im tired of it being dirty and ratty all the time. Im planning on replacing the carpet in my truck with a vinyl carpet, hopefully will make it easier to clean, also I ordered custom seat covers, and weather tech floor mats.
I might change out some if the dash panels and door panels eventually too
Anyone ever do a carpet swap/replacement? Any tips?
The vinyl carpet comin in the mail tomorrow so I'll start it next couple if days, I'll post some pics
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
metalman7.3 is offline
post #2 of 10 Old 08-21-2013, 09:24 PM
I've replaced carpet in a couple of trucks over the years-- take your time and remove everything you can first and it'll turn out great! Be sure to post pictures. Are you going to recover your seats?
Blue Rivet Rob
2003 e350 7.3L Diesel extended Explorer high-top conversion van
1998 e350 7.3L Diesel Chateau conversion van
Bluerivet is offline
post #3 of 10 Old 08-28-2013, 07:56 PM Thread Starter
Ok so I finally got some time to post some pics, heres the floor replacement:
The seats came out fine with a T55 driver.
It starts with a nasty disgusting mess:
Got all the seats out:
I found out that the previous owner had a dog... really really gross under those seats and I found like 6 forks. And about a hundred .22 rounds:
Putting in the liner that comes with the new carpet, gkueing it down with spray adhesive:
Here's what the new carpet looked like:
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
post #4 of 10 Old 08-28-2013, 08:09 PM
good start. im going to be replaceing mine in a couple weeks too.where did you get the carpet from?
badash is offline
post #5 of 10 Old 08-28-2013, 08:11 PM Thread Starter
Then I slowly started to trim the vinyl liner until it fit, anchored it in place with the seat screws, and that's pretty much it, I had to remove all of the trim pieces, and trim the liner to fit perfectly:
I tried to glue it down too, bit the adhesive never stuck to the vinyl so its not glued, bit neither are the factory carpets anyway, I just ended up with a few more wrinkles than I would have liked:
Put the trim pieces back in. an presto:
Them I pit the seats back in, after vacuuming them: and double presto there it is! An extremely easy to clean floor that will never soak up any liquid and stink really bad ever again!!!!:
It cleaned up the truck really nice. Made it smell new again, its pretty awesome
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
post #6 of 10 Old 08-28-2013, 08:24 PM Thread Starter
And then I ordered and installed custom seat covers from shear comfort, the 10 matched the factory interior color of my truck perfectly:
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
post #7 of 10 Old 08-28-2013, 08:28 PM Thread Starter
ACC carpets they have everything, it takes them about a week to fabricate it, cost about $180
I was real happy with how it fit, it fit the tranny hump pretty good.
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
post #8 of 10 Old 08-29-2013, 05:51 PM
alaskan155's Avatar
Quoted: 60 Post(s)
are those seat covers just slip overs or complete replacements?
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #9 of 10 Old 08-30-2013, 07:12 AM
basicbajax's Avatar
sound proof it while your at it. Home Depot duct insulation works great and it's cheap...
I used to think high mileage was a bad thing, but its a badge of honor on my F250 Powerstroke.
basicbajax is offline
post #10 of 10 Old 08-30-2013, 10:22 AM Thread Starter
There slip overs, they fit really well though, and they're waterproof.
I thought about it, but can't you put the insulation on underneath the truck? And I could do it on the firewall, the engine side...
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
